otáčky za studena
				Parez tdci
otáčky za studena
zdravím všechny,,,mam 1,8 tdci 74Kw 2003 při studeném motoru, když přidám a podržím plyn tak na 2000 ot/min tak začnou klesat a dusí se to a z výfuku mi jde dost velky oblak bílého dýmu... tohle se dějě jen když je motor studeny když je ohřaty šlape jak má... díky všem za odpověd,,,,  může to byt vaha vzduchu??
						- pelen
Re: otáčky za studena
DIESEL TROUBLESHOOTING WHITE SMOKE
White smoke usually occurs when there is not enough heat to burn the fuel. The unburned fuel particles go out the tailpipe and typically produce a rich fuel smell. It's not unusual to see white smoke in the exhaust during cold weather until the engine warms up.
As mentioned earlier, bad glow plugs or a faulty glow plug control module can cause white smoke on engine start up. Low engine cranking speed may also produce white smoke.
If white smoke is still visible after the engine has warmed up, the engine may have one or more bad injectors, retarded injection timing or a worn injection pump. Low compression can also be a source of white smoke. Air in the fuel system can also cause white smoke.
- racetiger
2PELEN:  This is very nice answer, but do You think that everybody understand Y?
						- pelen
Ta odpoved ohledne bileho dymu je tu urcite uz nekolikrat a s prekladem jiz mohou pomoct dalsi.
