1.6 Ecoboost - zvolavacia akcia 17S09
- Banny
Ahojte,
na zahranicnych EU forach ma uz kopec majitelov zaznam v ETISE na zvolavacku ohladom opravy motoru:
17S09
https://ford.oemdtc.com/2754/17s09-cool ... -2015-ford
Majitelia 1.6EB skuste si pozriet ETIS.
17S09
- Anduril
Re: 1.6 Ecoboost - zvolavacia akcia 17S09
Mam to tam... pujdu se poptat do servisu.
Ale jestli to chapu, je to jen nainstalovani senzoru hladiny chladici kapaliny... Coz je tak celkem na nic ne.
- Banny
Udajne maju montovat dodatocny senzor na meranie mnozstva chladiacej kvapaliny aby sa predislo havarii motora.
Som zvedavy ako to spravia a kde sa vlastne bude zobrazovat info a nizkej hladine chladiacej.
Ak budes mat nove info daj vediet
ja nemam 1.6EB ale celkom ma to zaujima.
- Anduril
No patrne ti v takovem pripade vyskoci chyba na palubnim pocitaci.
Prijde mi, ze spise meli resit, proc ubyva kapalina nekomu tolik, ze dojde k takovemu selhani. Uvidime.
- Banny
Na druhej strane taky senzor ma byt podla mna v aute od vyroby.
- Sagic
Videl jsem na youtube video s Kugou kde si na dalnici odpravil motor, jede cca 110 km/h od motoru desny zvuky nakonec to chcipl a uz nenastartoval... pry bez chladici a uvareny motor. Zrale na vymenu motoru... Na videu ale raficka uprostred a zadna kontrolka nesviti.
Je:
Byl:
Byl:
- Anduril
https://www.motor-talk.de/forum/rueckru ... 41050.html
Pry akce tak na 5 hodin.1. The engine is first checked for coolant loss (pressure test) and oil loss (especially at the cylinder head in the turbocharger area (behind the wind deflector).
2. If oil loss is detected in the above range, the cylinder head should / should be changed.
3. The air intake (air filter box and pipes to the rear left) and the battery box must go out, because on the battery box (left outside) a new cable distributor is mounted and
4. underneath a plug connection is disconnected and the new wiring harness is inserted.
5. The alternator has to go out, because most of them have to replace the coolant thermostat (82 degrees).
6. The coolant tank and a few hoses are changed.
7. The engine coolant bypass valve is replaced.
8. A coolant standpipe is newly installed (right behind the coolant tank (see photo)) and connected to the new wiring harness / hoses.
9. The engine control module (PCM), body control module (BCM) and instrument cluster (IPC) receive a software update.
- Sagic
Chapu dobre ze je to jen pro 2013+ vyrobu?
Je:
Byl:
Byl:
- Anduril
Ne, je to asi pre vsechny 1.6 EB, ja mam 2011. Pokud to v Etisu vidis, tak se te to tyka.
Nicmene nevidim tam Mondeo, Smax, Galaxy.
Fiesta ST (Cologne plant): 19 September 2012 to 16 December 2014
Focus (Saarlouis plant): 23 July 2010 to 21 September 2014
C-MAX (Saarlouis plant): 2 June 2010 to 22 December 2014
Kuga (Valencia plant): 8 May 2012 to 21 November 2014
Transit Connect
- Sagic
Etis jsem zkousel ale bud s nim neumim nebo to tam nemam. Pise mi jen ze pro moji zemi nic neni nebo tak nejak a ze mam zkusit zmenit nastaveni.
Je:
Byl:
Byl:
- djdekl
- Sagic
WF0LXXGCBLCY62731
Je:
Byl:
Byl:
- phofy
Máš to tamSagic píše:WF0LXXGCBLCY62731
- Sagic
Diky diky. Dejte vedet az budete mit nekdo info... Ja pojedu kolem fordu cca za tyden (mam si tam neco vyzvedavat) tak se taky preptam ale drive se tam nedostanu.
Je:
Byl:
Byl:
hudyss77
Můžu taky poprosit
WF0HXXWPBHBS28943
WF0HXXWPBHBS28943
Ford Grand Cmax – 1,6 EB Titanium 134kw – 2011 viewtopic.php?f=239&t=47846
