Radio pise LOCKED
Lukacenko
Radio pise LOCKED
Ahoj vsichni,koukam tu a nejak nemuzu najit jestli se resilo zablokovani radia kdyz je tam napsano LOCKED a ve fordu mi rekli at ho vyhodim a koupim si novy.Umi to nekdo odbloknout?
Diky vsem a omlůouvam se jestli se to tu uz resilo...
- Boban
Re: Radio pise LOCKED
no ono jde všechno
, ale bude levnější udělat to co ti radí ve fordu, nevím co máš za rádio, co za auto, já prodával radio na cd za 2500
Ford Galaxy 2.0 \tdci
MB W124
Ford Fiesta 2007
old Mondeo galerie
MB W124
Ford Fiesta 2007
old Mondeo galerie
zirafak
Poradili ti spravne.Hodit do smetiaka,lebo niekto zadal vela krat nespravny kod a ochrana ho zablokovala natrvalo.
Lukacenko
Tak to jste mne moc nepotesili...Jsem ted volal jeste jednomu servisakovi a prej uz se s tim setkal,ale nevyplati se to financne
Stejne Vam moc dekuju a jsem rad,ze je takovy supa forum a fajn lidi...
Lukacenko
Jo a mam radio 6000 CD a ford focus kombi 1,8 TDDI 2000 r.v. a fotky budu davat hned jak se k tomu dostanu
- pelen
A co jeste se pokusit:
Ford Radio showing LOCK10
Solution
If your Ford Radio is showing LOCK10 it means you have used up your 10 chances
at entering the correct code, however this can still be by-passed on most models
to give you a further 3 chances.
Use with caution and ensure you have your correct code, available by entering your
serial number on our website.
If you enter a further 3 Incorrect codes your radio will show LOCK 13 and will need
to be sent into us for unblocking.
How to bypas Lock10
Turn on your ignition, ensure the radio is off.
Press and hold preset button 6 whilst turning on your radio.
Ford Radio showing LOCK13
Solution
If your Ford Radio is showing LOCK13 it means you have used up your 13 chances
at entering the correct code, your radio will now be permanently blocked
and will need to be sent into us for unblocking.
There is no other way around this and Ford dealers have been known to charge in excess
of £60 + vat for the same service as we offer.
Click here for further information on our LOCK13 reset decoding
Nekteri to snad umi i odblokovat, aby se uz pin nemusel davat.
Solution
How to bypas Lock10
Solution
- FOCKI
kde ty na to chodíš Pelene
chmelko
myslím, že je to v servisnom manuale
- FOCKI
tak to se vysvětluje, já nemám
- Skubi
tož nevím, ale já v příručce k rádiu mám tohle:
Objeví-li se "LOCK 10" nebo "LOCKED", je jednotka natrvalo neprovozovatelná.Kontaktujte svého místního dealera firmy FORD a požádejte ho o radu a pomoc.
chmelko
Skubi:no presne a Pelen ti citoval servisny manual pre dealera..servisy, ak sa nemylim
- pelen
Je to nalezeno nekde na anglickem serveru, uz jsem to tu daval. Normalni lidi se mohou splest 10x (Lock10), to se da ale rozsirit jeste o tri az na Lock13 popsanym postupem.
Pak uz jen placena vymena epromky uvnitr radia.
zirafak
Lenze Lukacenko asi ani nevie,kolko krat tam niekto ten kod zadaval.
Lukacenko
Zirafaku,ale vim,jsem debil,ten kod jsem tam zadal 10 spatne ja a ted si rvu vlasy
... Vubec jsem netusil,ze se mi to zablokuje nadobro...
Lukacenko
Pelene,ten anglickej navod mi prelozila mlada a ze prej to je jen navod a jsou bud 3, a nebo 10 pokusu a pak je to KO,ale stejne dik za rada u namahu
